96 3.2L Ignition Problems
Old Nov 1, 2009 | 07:36 PM
paulwschubert's Avatar
Default 96 3.2L Ignition Problems
I have a 1996 Rodeo LS with the 3.2L V6. It has a hard time starting. Engine cranks but will not start. Also every once in a while, it will die while driving. I noticed that when the key is turned to the ACC position, only 3 of the idiot lights will light up. If you keep turning the key back and forth, all the lights will eventually come on, you hear the fuel pump prime, and it starts. It also will do this if you just let it sit in the ACC position for a while. Tried replacing ECU and ignition start switch. Same problem. Any ideas?
morphix
Apr 1, 2012 11:15 PM
jackc396
Oct 3, 2009 02:53 PM
surpera1
Aug 4, 2009 05:11 PM
Gundam79
Jul 4, 2009 12:56 AM
Gundam79
IF Help & Suggestion Center
Jul 4, 2009 12:52 AM
