94 passport/rodeo MPG improvent
Old Aug 8, 2006 | 08:05 PM
passport105's Avatar
I've got a 94 V6 4WD Passport/Rodeo. Is there anything I could do to increase the MPG? Here is what I can think of:
1. air intake upgrade
2. exhaust cutout MAYBE
3. remove 5th wheel andrack on back
4. remove rusted trailer hitch
5. remove rear seats
Old Aug 8, 2006 | 09:10 PM
Not alot you can do. None of those things will make much difference if any . In fact cold air intake can actually hurt mileage. More air = more fuel to get a propper burn. Exhaust cut out would definatly hurt mileage, it will kill low end torque so you will use more gas on take offs.
About all you can do is keep it tuned up, use all synthetic fluids (some debate on this), drive like an old lady, keep tire pressure up.
I always fill tires above what the owners manual says. Thats usually good for a couple MPG and the tires dont wear any different. Mine says to set to 29 front and back. I run them at 35 (max on my tires is 50).
Old Aug 9, 2006 | 12:34 AM
The way I understandCAI is the engineis supplied with denser air, which in turnhelps the engine breathe better and so it doesn't have to work as hard. You're probably right about the cutout though, it varies from car to car. Thanks for the reply!Edited by: passport105
Old Aug 9, 2006 | 02:42 PM
redneckrodeo's Avatar
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNABLE="on">
<T>
<TR height="100%" width="100%" UNABLE="on">
<TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNABLE="off">there is a device called a tornado you put it in your intake tube havent tried it but it might be something to look into it is designed to produce better fuel economy</TD></TR>
<TR UNABLE="on" hb_tag="1">
<TD style="FONT-SIZE: 1pt" height=1 UNABLE="on">
<DIV id=hotbar_promo></DIV></TD></TR></T></TABLE>
Old Aug 9, 2006 | 04:01 PM
I tried one of those tornado fuel savers on a v6 camaro that I had a while back.They're a rip off.
Old Aug 9, 2006 | 10:11 PM
<T>
<TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNABLE="off">are they i didnt know i couldnt see how it would work but just thought i would tell you about it</TD></TR>
<TR hb_tag="1" UNABLE="on">
Old Aug 10, 2006 | 02:34 AM
Check out this article on "fuel savers".
http://www.popularmechanics.com/auto..._cars_trucks/1 802932.html
tiogij
Wheels and Tires
Nov 21, 2012 05:47 PM
originalowner
Jan 19, 2011 08:19 PM
passport105
Feb 16, 2009 11:16 AM
vetfromindy
Nov 3, 2008 03:29 PM
sublime96
Axiom
Oct 13, 2008 01:27 PM
