Tire PSI setting and Better MPG ?
Old Sep 9, 2008 | 01:11 PM
sublime96's Avatar
Im wondering what All of you have your tire pressure set at?
Ive noticed my average MPG have been getting lower ..... ??? ....?
I am trying to find Ways to improve my MPG in Any way... Tire PSI seems to be a good start on this.
Thanks every1[img]smileys/smiley2.gif[/img]
Old Oct 4, 2008 | 02:09 AM
kevin1970beetle's Avatar
35 is the max (safest) tire pressureDO Not go above it or your chances of having a blow out or worse go up
Old Oct 13, 2008 | 01:27 PM
Paul's Avatar
On my Yokohama tires I have 28 psi. Check your gas station to see how much ethanol is in the gas. With no ethanol I get 19.5+ mpg. With ethanol now I get 18 to 18.5 at 10% ethanol. The higher the ethanol content the more my mpg drops. Some stations have 15% or more around here. (SE Pa). Don''t forget to use fuel injector cleaner once a month. Also a clean air filter helps.
nembuzz
Concept and Rumor Mill
Apr 26, 2011 02:09 AM
originalowner
Jan 19, 2011 08:19 PM
Full Pull
May 24, 2010 03:07 AM
passport105
Feb 16, 2009 11:16 AM
