93 rodeo - 10 sec run, then die...?
Old Jul 1, 2010 | 05:26 PM
squeek's Avatar
Default 93 rodeo - 10 sec run, then die...?
ok i had this thing running and driving. it only has about 200 miles on a new head gasket install. but the lights werent working (got it needing the head gasket, so never checked anything else) turn out the lights work when i barely loosened the screws under steering column cover... sounds like a screw was shorting out the lights... well now it wont run longer than 10-15 seconds! was told it was the MAF, so after a 2 month long search i finally found one, put it in, and still same thing! any ideas? could there have been something in the column that i loosened to make the lights work, that made the motor not get some sort of electrical power to the inj or comp or?
annamarie.johnson
Feb 21, 2012 02:23 AM
beretta92
Jan 1, 2010 10:13 PM
jibe
Feb 24, 2009 02:35 PM
dane
May 17, 2008 01:14 AM
