03’ Rodeo aux driving lights...
Old Mar 4, 2008 | 08:13 PM
80s AL's Avatar
I put a set of Factory aux Driving lights on my wife's Rodeo a few years back....
All of a sudden, they BOTH don't work. The light on the dash button still works, but no lights...
Relay? Somethin else?
Thanks
80's AL
_uacct = "UA-939292-44";
Old Mar 4, 2008 | 11:26 PM
Relay or fuse most likely.
Old Mar 5, 2008 | 05:25 AM
80s AL's Avatar
all fuses are good....that is why I was thinkin relay.
In the fuse box as well, right?
How do I check if thay are bad?
Old Mar 5, 2008 | 01:02 PM
I believe the relay is in the fuse box by the battery in the engine compartment. You could just swap with another relay thats in the box temporarily to see if it works. If not then its probably not the relay.
Old Mar 6, 2008 | 04:52 AM
Mike124's Avatar
Most like the relay my ex-01 Ford Ranger XL factory fogs i add-on had big relay problems need to be replace every 9 months until i found the water leak.
Mike
pkanu
Feb 14, 2009 08:27 AM
the wolverine
Feb 8, 2009 03:48 PM
Middawg2
Sep 7, 2008 08:38 PM
Trooperguy
Aug 28, 2007 07:35 AM
n0walker
Sep 7, 2005 11:30 PM
