< src="http://www.google-analytics.com/urchin.js" =text/> </> I put a set of Factory aux Driving lights on my wife's Rodeo a few years back.... All of a sudden, they BOTH don't work. The light on the dash button still works, but no lights... Relay? Somethin else? Thanks 80's AL < =text/> _uacct = "UA-939292-44"; urchinTracker(); </> |
Relay or fuse most likely.
< src="http://www.google-analytics.com/urchin.js" =text/> </> all fuses are good....that is why I was thinkin relay. In the fuse box as well, right? How do I check if thay are bad? < =text/> _uacct = "UA-939292-44"; urchinTracker(); </> |
I believe the relay is in the fuse box by the battery in the engine compartment. You could just swap with another relay thats in the box temporarily to see if it works. If not then its probably not the relay.
Most like the relay my ex-01 Ford Ranger XL factory fogs i add-on had big relay problems need to be replace every 9 months until i found the water leak.
Mike < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44"; urchinTracker(); </> |
