02 Rodeo 3.2 Crank, No Start
Old Feb 17, 2020 | 05:18 PM
HenryW's Avatar
Default 02 Rodeo 3.2 Crank, No Start
Finally picked up my first Isuzu! I bought a 2002 Rodeo 3.2 RWD. Lady thought it had a bad head gasket. Towed it home and turned out to only be water pump... Scored!
Replaced TB and water pump, new plugs and she ran great! (Just around the block, no tag yet). AC didn’t work so I filled with 134/dye. Found bad Orings and replaced, recharged.
So, done charging ac, shut it down to clean up and no start? Wth? Grabbed my fuel pressure gauge and nothing, even during crank. 1/2 tank gas. So jumped fuel pump relay and pressure goes up, truck starts. Switch with good relay and nothing, pump doesn’t turn on.
Is there an anti theft I’m missing? Fob works fine, even tried using key in drivers door to lock, unlock.
I’m lost. Any advice?? Thanks a lot in advance!!
Old Jun 5, 2020 | 11:59 PM
Shanika Carlock's Avatar
Default IsuzuRodeoBlues
Did you ever find out anything. Currently broke down
Old Nov 23, 2020 | 08:08 PM
Bryan Sarles's Avatar
this very thing happened to me, turned out that my fuel pump fuse blew, fuel pump died. Jumped relay got same result as you did. Bad fuel pump. At 150k I was on borrowed time
Trouble
Nov 23, 2016 06:01 PM
mac92a2002
Apr 29, 2015 09:00 PM
tripplekill
Sep 24, 2011 02:52 AM
jac87
Oct 3, 2009 02:51 PM
☻ר&
Jul 6, 2008 12:47 AM
