1996 3.2 Rodeo Rough Start
Old Aug 25, 2009 | 05:30 PM
jac87's Avatar
Default 1996 3.2 Rodeo Rough Start
I recently purchased a '96 rodeo with the 3.2 in it. When I go to turn the key the motor will turn over an excessive amount of times before it actually starts. I have replaced the fuel filter, and it seemed to help almost immediately, but then went back to the normal symptoms of a rough start. I are plugs and wires next? Any other suggestions?
Thanks
Old Aug 30, 2009 | 06:45 PM
towingwithmyisuzu's Avatar
Yeah i'd try plugs and wires, since they are routine maintenance anyways....
if not maybe the coils?
Old Sep 2, 2009 | 09:10 PM
96isu's Avatar
i also have a 96 rodeo with the same problem and i resolved it by putting in the good gas like chevron and shell in it because i was putting in the cheap gas
Old Sep 3, 2009 | 01:53 PM
rotarynut's Avatar
Again, no autorized Isuzu mechanic but here are my thoughts. The problem is there, and you have helped it but have not solved it. While plugs and wires are proboly due and needed, I am thinking fuel pressure related. The pump only pumps a little before it shuts down and then has a moment before it pumps again. Replacing the fuel filter may have improved flow of fuel, but there may still be crud in the tank. Also a poor fuel regulator can cause the same issue. I'd just test for fuel pressure at start up to see where it is at. It's an easy test and doesn't cost any money. Just my thoughts.
Old Sep 4, 2009 | 10:26 AM
ElectroGhandi's Avatar
Make sure your gasoline is pure. If nothing else works, try getting the tank completely pumped and then putting in new gasoline.
Also make sure all your cylinders are firing.
Old Sep 5, 2009 | 07:54 PM
jac87's Avatar
So check the fuel regulator? I thought about possible crap in the tank. As far as all cylinders firing, it pulls pretty strong and idles well. It has 130,000 on it, so as far as the plugs and wires your probably right. How much does it cost to have the tank pumped or can i do it myself?
Thanks for all the input
Jesse
Old Sep 6, 2009 | 09:29 PM
rotarynut's Avatar
You can deop the tank and pour out the old gas, but i'd wait until the tank is as close to E as you can get it. It will make it that much lighter. It's not hard just time consuming.
Old Sep 6, 2009 | 09:30 PM
  #8
rotarynut's Avatar
I meant drop the tank.
Old Oct 1, 2009 | 01:48 PM
  #9
jac87's Avatar
Hey guys I've got a new part to add to the problem. This last week sep 26-Oct 1 the weather here in N Georgia has gotten kind of chilly low forties at night/early monrings, and the car has been starting right up like it should-indicating that possibly is has something to do with a thermostat or some kind of electric choke.
Is there something that i can check along those lines or replace?
Thanks
Jesse
Old Oct 2, 2009 | 10:01 AM
  #10
rotarynut's Avatar
Just a thought, but in my racing days we used to pack a "cool can" to get the fuel cold. The fuel when cold seems to form for lack of a better word better droplets than when warmer. This seemed to put more fuel in the chamber and get a bigger burn. This may be whats happening in your case which might suggest again poor fuel pressure or a faulty or dirty injector. If the fuel injection "squirt" is just on the borderline in a cylinder or cylinders than I could see this. Just thoughts. Try running some injection cleaner through the tank. By the way, did you check the fuel pressure at start up?
