1990 Isuzu pickup 2.6 Stalls when cold, runs fine warm
Old Oct 4, 2010 | 12:51 PM
gpxfiles77's Avatar
Default 1990 Isuzu pickup 2.6 Stalls when cold, runs fine warm
Hi,
I was hoping somebody could help me out. I just had the head gasket and head repaired on my 1990 Isuzu Pup 2.6. When I picked up the truck, the idle was very high. The mechanic said he had to do that otherwise it would stall when cold. Translation - he could not figure out why the pickup would stall when cold so he just cranked up the idle. The problem is I couldnt drive it that way since shifting in drive or reverse caused the pickup to lurch forward or backward. I asked him to reduce the idle, he did warning it would be difficult to keep it running when cold. I said "fine" please do it anyway.
So now when cold the pickup stalls out at idle. I have to drive it initially with one foot on the gas and one foot on the brake and ride the brake pretty hard at anyting less than 5mph to keep the truck running. Once it warms up its finel.
The mechanic said he replaced all the vacuum hoses he could find.
I pushed on the EGR valve, it does move back and forth but I have to push a bit, kind of stiff. Could the EGR cause this problem?
Any other ideas? Any help appreciated.
Thanks
Old Nov 3, 2010 | 07:24 AM
davor988's Avatar
Sneaker News | LudaKicks | September 28,Onitsuka Tiger Shoes New Arrival, 2010 at 4:00 pm Last anniversary UGSoles brcare you a attending at the Asics Gel Lyte III “NiceKicks 2.0&Paperture;?archetypaled by Linette Torres, now we accompany you the absolution advice for these burning abstract!?As a lot of of you apparently 5ec17b5accomplishment5ada6031f642a1f604798 this is the additional Nice Kicks x Ronnie Fieg x Asics this brace accomplishmenturing a bland Cool Grey and WHite blushup with the use of exceptional abstracts. You can get these alone at the Nice Kicks in Austin,http://www.shoesasics.net/, Tx. as able-bodied as David Z in NY and?DavidZ.com at 10AM EST. Good Luck to all!!Nice Kicks2815 GuadalupeAustin, TX 78705512.320.8100Dardent Z556 BarteryNew York,Asics Gel Kinsei 2, NY 10012212.431.5450 Asics Gel Stratus 2.1 Shoes Yellow / Grey relative item: http://www.mycharmingwedding.com/showthread.php?t=26908 Slam Jam x Asics Gel Lyte III – Available Oakley Jupiter Sunglasses--Asics GEL Noosa Tri-6 C
rander
Pickup
Dec 8, 2010 03:45 AM
moospis
Pickup
Dec 9, 2009 07:42 AM
moospis
Pickup
Apr 24, 2009 09:47 AM
maestro379
Pickup
Feb 26, 2009 02:56 PM
Isuzumania
5
Nov 2, 2005 10:04 PM
