Transmision light and Engine light
Hello, I have an Isuzu Amigo 2000 I need some help. Got the transm light blinking and the engine light on.......about 1 yr ago had problems with the tramsmision....any suggestion what can it be? Thns
yes misting the wires includes misting the coil pack.
There was no evidence of any arcing of the coil pack...the plug wires showed some arcing. I'm going to change the plugs, and run some sea foam through it today. ------------- locksmith nyc |
Most transmission-related noise happen at transition speeds. It happens during acceleration or deceleration in most cases, and idling in bad ones. The power works out the difficulty. It could be anything from a low allowance of lubrication to chipped gears.
