right three cylinder not firing
Old May 25, 2025 | 04:44 PM
Uncle Senior's Avatar
Default right three cylinder not firing
Hello everyone. Installed New timing belt belt, water pump etc, everything aligned Perfectly My 1998 3.2 not firing on complete right bank, I Triple check timing marks everything checks, It starts right up... however now the right side is not firing. I did a compression check I have 140 lbs all three cylinder ! , I pulled the coil pack attached a spark plug started vehicle I have spark consistently on all three cylinders !, replace the spark plugs still no joy. Fires right up idle's, check engine light pops, says multiple misfire on code Triple check timing again all is in synch ! HELP when i disconnect the coil pack when running individual cylinder right bank still nothing, but coil pack is sparking plug AHHHHHHHHHHHH,, Help please
{*losh*}
Mar 8, 2011 02:24 AM
KDemarest7725
Feb 27, 2010 10:49 AM
triguy
Nov 16, 2008 08:11 PM
RodeoRaymon
Dec 28, 2007 07:38 PM
cricketo99
I-Mark
Jun 24, 2007 04:14 PM
