NOT SURE?!
Old Oct 4, 2007 | 08:20 PM
AmigoMan's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I just bought my 1994 Isuzu Amigo, 5 speed, 152,000 miles.. Runs great.. But my concern is when I get into higher RPM's.. It squeeks a little, I also tried it in Nuetral and it does the same in higher RPM's. Not sure what it was, I oiled the belt with some WD-40, it stopped for a mile then started back up.. Anyone have any idea of what it may be??
Old Oct 6, 2007 | 11:19 AM
AmigoMan's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
NO MORE SQUEEKS! Got a new alt/crank/fan belt.. And also a new power steering belt.. Also I changed the oil, differential fluids, and clutch fluids.. And took out the AC belt, figured I don't use it, and its blocking my alternator which I needed to get to, in order to change the belt.. So I did away with it. Now I have a minore problem and I am not sure what it is.. It has a rough Idle when in neutral, could it be I tightened the belt too much? Or does taking the air conditioning have something to do with it.. May it be something else? Please help me out!
Old Oct 29, 2007 | 03:40 PM
totalamigo's Avatar
try changing the pcv valve. If that doesn't work, try the O2 sensor
Old Oct 29, 2007 | 03:41 PM
totalamigo's Avatar
also, try looking for a vacuum leak, my 94 has some vacuum lines that are looking pretty bad, will be replacing them all shortly
Old Mar 14, 2008 | 07:24 PM
isuzunj's Avatar
if your still having the problem try cleaning the throtle body. with the car off, take the air intake tube off the throtle body. pull on the gas cable untill the valve opens, then take carburator cleaner spary on a rag and clean the other side of the flap. when u think you got it all put it back togetheir, and start your car. it might seem like its choking out but it will start and should be fine.
Zachary Keith Collett
Apr 8, 2014 11:31 PM
Junk_monk
Apr 4, 2009 02:23 PM
ennis1979
Feb 23, 2006 03:40 PM
lukera
Jan 10, 2006 07:26 PM
hardline71
Aug 30, 2005 02:30 PM
