Coil packs
Old Mar 25, 2012 | 01:45 PM
94IT's Avatar
Default Coil packs
I just changed a coil pack on my 1995 Isuzu trooper and it ran worse than it did with the old one. then it died and wouldn't start again, so I took the new coil pack off and it started and will run on four cylinders. When i try to put the coil pack back on it will not start. I am completely perplexed, any help would be appreciated.
So I just had a mechanic come over and we figured out that it was the plate that the coils sit on. 50 bucks at the junkyard and I'm rolling again.
Last edited by 94IT; Mar 26, 2012 at 05:05 PM. Reason: Found out what the problem was.
Old Apr 9, 2012 | 10:04 PM
sheltonjason's Avatar
FYI you can have both coil pack and mounting plate tested at your local auto parts store. It's usually a free test the only challenge is finding an employee that knows how to properly run the equipment. Be sure to have them test the mounting plate about twenty times so that it heats up enough to get an accurate test.
tcseadoo
Sep 3, 2011 05:41 AM
JimmyK
Nov 26, 2008 01:21 AM
edl63
Apr 29, 2008 04:47 AM
Rickster
Jan 9, 2008 09:19 AM
dohash
Jun 23, 2007 06:47 PM
