Rims / Wheels
Old Nov 22, 2011 | 02:15 PM
alanauer's Avatar
Default Rims / Wheels
Can't find used rims for my 1990 2WD PU. Anybody happen to know what other vehicle wheels would fit? Mine has 14-inchers but 15-inchers would work.
Old Nov 26, 2011 | 02:53 AM
d12cons34's Avatar
dude go for the work shop and u could find right size of rims that will fit for ur car
Old Nov 27, 2011 | 03:39 PM
alanauer's Avatar
Thanks for your suggestion but I brought the truck with me to Canada where that model is not sold, so tire shops, salvage yards, and former dealers have no listing for it.
That's why I hoped someone might know if rims off, say, a Trooper or Amigo would fit. The distance from one bolt-hole across to the opposite one (there are 6) is 5.5" and the diameter of the center-hole is 10.5cm but it looks like there'd be some wiggle-room on that.
Old Dec 19, 2011 | 11:04 AM
andersongreen's Avatar
good post and it would help me lot thank you guys...
Old Jan 5, 2012 | 12:31 AM
ethanvalit's Avatar
For new businesses investing in extravagantly pricey equipments might not be possible. Not just are these heavy equipments a little too costly but with newer and much more handy options obtainable; their investment can completely be avoided.
Old Jan 13, 2012 | 09:40 PM
Taylorcarter's Avatar
Hi guys,
good post and it would help me lot thanks
Old Jan 14, 2012 | 08:51 AM
alanauer's Avatar
Is the main requirement of posting to this thread some kind of mental impairment?
Old Jan 16, 2012 | 03:22 AM
  #8
spatajon's Avatar
Old Jan 16, 2012 | 08:07 AM
  #9
Lui95LS's Avatar
It seems that there is a lot of spam going on on here...
I think the 6 bolt rim pattern is standard... 6x5.50 or 6x139.7
I would try a wheel retailer website they should be able to give you all specifications for the wheels you need...
There is no real wiggle room... You the center hole must have a tight fit on the hub, you should never mount wheels centered by the wheel nuts...
I know the later model Trooper II come with 16 inch rims and are 8 inches wide...
Good luck in your search... Luis
Old Jan 17, 2012 | 07:46 AM
  #10
alanauer's Avatar
Thanks Lui -- the only helpful response after over a year. The wiggle-room was the thought that if the hub-opening was a bit too small I could grind it out to fit.
The only used 6-bolt rims with winter tires on them I can find around here had been made for some GM trucks. Do you think they'd fit? (It's not just a matter of matching the holes but of offset, brake-parts clearance, etc., so seems to be a matter of trial-and-error.)
