3.5l v6 non-interference or ???
Originally Posted by isha0018
Have a quick question that I have been searching all over the web for... is the 99 3.5l v6 trooper an interference motor? Thanks in advance
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
im getting conflicting info about which engines are "benders" and which arent. im considering buying a 95 trooper with a 3.2L with a timing belt "issue". i only want to buy it if is NOT a interference engine. how sure are you that this one is not? do you have first hand knowledge?
thats good, your lucky!!
it probably didn't bend anything cus the belt didn't actually snap (i'm assuming since you said it jumped time) and it just went slack and didn't swing around and bend everything...
hfork
Sep 19, 2006 03:30 AM
