Have a quick question that I have been searching all over the web for... is the 99 3.5l v6 trooper an interference motor? Thanks in advance
< =""> <! var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //> </> |
im getting conflicting info about which engines are "benders" and which arent. im considering buying a 95 trooper with a 3.2L with a timing belt "issue". i only want to buy it if is NOT a interference engine. how sure are you that this one is not? do you have first hand knowledge?
Both the year 99 3.5L and the 95 3.2L engines are interference motors.
I wouldn't shy away just because it's an interference motor, just keep up on the timing belt and it is a great engine :) |
i have one a 95 and the t-belt went out, bent two valves, no it sits in my back yard
Weird because i replaced a the timing belt in my 1995 trooper w/ 3.6l dohc and its running like normal... mine jumped time due to a broken tentioner pully
Originally Posted by tburkejr
(Post 43038)
thats good, your lucky!! it probably didn't bend anything cus the belt didn't actually snap (i'm assuming since you said it jumped time) and it just went slack and didn't swing around and bend everything... :D |
