HELP ME!!
Old Oct 4, 2007 | 07:09 PM
AmigoMan's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Hey I got post 200 up on Amigos, ya boy.. Anyways, I just bought my 1994 Isuzu Amigo, 5 speed, 152,000 miles.. Runs great.. But my concern is when I get into higher RPM's.. It squeeks a little, I also tried it in Nuetral and it does the same in higher RPM's. Not sure what it was, I oiled the belt with some WD-40, it stopped for a mile then started back up.. Anyone have any idea of what it may be??
Old Oct 4, 2007 | 08:27 PM
Keefbikes's Avatar
If it went away AFTER you oiled the belt, it is the belt. WD40 is a poor lubricant, it has a very short life span and leaves no residual to lubricate. I would just adjust the belt tighter and see if that will get rid of the squeak. If not may be a bent pulley or a bad bearing, but it sounds like a loose fan belt to me. Good luck and please post what you find.
Old Oct 6, 2007 | 11:18 AM
AmigoMan's Avatar
NO MORE SQUEEKS! Got a new alt/crank/fan belt.. And also a new power steering belt.. Also I changed the oil, differential fluids, and clutch fluids.. And took out the AC belt, figured I don't use it, and its blocking my alternator which I needed to get to, in order to change the belt.. So I did away with it. Now I have a minore problem and I am not sure what it is.. It has a rough Idle when in neutral, could it be I tightened the belt too much? Or does taking the air conditioning have something to do with it.. May it be something else? Please help me out!
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
trooper90
Dec 1, 2006 04:49 PM
hrosenbaum
Feb 15, 2006 01:04 PM
chuckie
Pickup
4
Dec 28, 2005 09:49 PM
98ZuZu
Apr 12, 2005 10:01 PM
RODEHO
Mar 7, 2005 12:29 PM
