Valve tick
Old Nov 14, 2021 | 12:51 PM
Woenellie's Avatar
Default Valve tick
I have a ‘97 Trooper with a valve tick. I called a shop and I was told by the shop this isn’t an issue that can be fixed, just replaced due to the hydraulic valves. Is this true? Or any ideas what to do?
Old Nov 15, 2021 | 06:38 AM
Winterhorse's Avatar
Default Try Sea Foam
A SeaFoam Engine flush is worth a try.
Old Dec 24, 2021 | 05:17 PM
Hooligan's Avatar
I'm guessing you have a bad hydraulic lifter. Are you saying that they were just replaced? Can't imagine why it can't be fixed. You can likely find the bad cylinder with a compression test and just change the bad one or change them all. It's not that hard and they're not all that expensive.
Old Dec 29, 2021 | 12:22 AM
EBasil's Avatar
Here's an old school fix: Marvel Mystery Oil. Read the can, pour the magic red sauce.
My ticks went away.
trooper93hc
Jul 11, 2017 12:59 PM
shane.bowser
Aug 28, 2012 04:15 PM
james_t
May 27, 2012 07:52 PM
MCharlie
Jan 9, 2009 02:04 PM
speed_demon
Oct 4, 2007 11:44 PM
