Valve Cover Replacement
Old Dec 26, 2008 | 07:53 PM
2busy's Avatar
hey all,
i own a 96 trooper 3.2 v6. i''m grasping at straws on a repair to hopefully clear my check engine light problem. the diagnostics codes read at the auto parts store mentioned that i had a misfire on #5 cylinder and a possible cam sensor problem. Changed spark plugs/cam sensorand noticed oil on the #5 plug. i am changing the tube seals and plan on replacing the valve cover gasket. The new gasket fits into the valve cover fairly self explanatory. However, all the manuals and readings i can find mention silicone rtv sealant application. Where do we put the silicone - all over the valve cover? all over the gasket? In between the gasket and cover? Between the new gasket on the valve cover and the engine?
any help would be great.
Old Dec 27, 2008 | 06:30 PM
JLEMOND's Avatar
Originally Posted by 2busy
hey all,
i own a 96 trooper 3.2 v6. i''''m grasping at straws on a repair to hopefully clear my check engine light problem. the diagnostics codes read at the auto parts store mentioned that i had a misfire on #5 cylinder and a possible cam sensor problem. Changed spark plugs/cam sensorand noticed oil on the #5 plug. i am changing the tube seals and plan on replacing the valve cover gasket. The new gasket fits into the valve cover fairly self explanatory. However, all the manuals and readings i can find mention silicone rtv sealant application. Where do we put the silicone - all over the valve cover? all over the gasket? In between the gasket and cover? Between the new gasket on the valve cover and the engine?
ONLY OPUT THE SILICON ON THE CORNERS WHERE THE VLV COVER GO OVER THE END CAM SUPPORTS, NOT OVER THE WHOLE THING
IT WILL BE SO SLIPPERY THAT IT WILL LEAK FOR SURE OR YOU WILL NEVER GET IT OFF AGAIN, JERRY
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Mr 2.3
Aug 24, 2011 11:34 PM
Flashgdn
Jan 18, 2011 05:28 PM
SniperCat
Oct 18, 2010 11:34 PM
hugh
Feb 29, 2008 11:00 AM
dane
Dec 4, 2007 06:52 PM
