Turbo for 88
Old Jan 20, 2006 | 05:20 PM
Jim Bob's Avatar
Can a turbo be fitted to a 1988 with a 2.6? If so, what would be the proper equipment?
Old Jan 26, 2006 | 09:01 AM
lowtrooper's Avatar
well, you would need the following:
custom made exhaust manifold
good quality turbine
blow off valve
intercooler(optional)
custom bent tubing
if you want to use more than 5 to 10 psi of boost you may need:
high flow fuel injectors
high flow fuel pump
adjustable fuel regulator
better ignition
colder spark plugs
I have never heard of a turbo trooper before. I have considered it before, but the approx price of installing a turbo is $2,000 andmy 89trooper is not worth half of that.
I have heard of 5.0L mustang engine swaps. I dont know if they keep the stock tranny or if they swap it out for another one.
Has anybody in this forum swapped out or modified their trooper engines?
shlbyturbo
Mar 20, 2018 06:50 PM
Rodeo_97
Nitrous, Super Chargers, & Turbos
8
May 17, 2008 02:01 AM
upgtx
Jun 30, 2006 01:05 PM
jiw395
Apr 4, 2006 03:21 PM
specman
May 6, 2005 04:03 PM
