Can a turbo be fitted to a 1988 with a 2.6? If so, what would be the proper equipment?
well, you would need the following: custom made exhaust manifold good quality turbine blow off valve intercooler(optional) custom bent tubing if you want to use more than 5 to 10 psi of boost you may need: high flow fuel injectors high flow fuel pump adjustable fuel regulator better ignition colder spark plugs I have never heard of a turbo trooper before. I have considered it before, but the approx price of installing a turbo is $2,000 andmy 89trooper is not worth half of that. I have heard of 5.0L mustang engine swaps. I dont know if they keep the stock tranny or if they swap it out for another one. Has anybody in this forum swapped out or modified their trooper engines? |
