trooper transmission
Old Nov 28, 2008 | 10:58 PM
terry's Avatar
How do you check ( where in the engine compartment )the transmission fluid and add some? automatic trans
Old Dec 10, 2008 | 05:37 PM
diesel3333's Avatar
There should be a threaded plug, similar to the drain, but higher on the transmission casing. Fill with Dexron III to the point it starts to drip out of the fill hole. Transmission should be warm with the trooper on a level surface.
spearbang
Aug 11, 2008 04:59 PM
mark
Jan 29, 2008 06:49 PM
DarkSideofWill
I-Mark
Jan 25, 2008 12:56 PM
gemmett
Oct 20, 2007 11:53 AM
mrcosmo
Nov 28, 2005 12:51 PM
