Trooper II light bulbs
Old 07-17-2012 | 02:47 PM
hoosier58's Avatar
Default Trooper II light bulbs
I'm replacing the right headlight housing on my 1990 Trooper, so decided to check all of the bulbs while I'm at it. My parking light bulb on that side is out, but I have one on the driver side. It's a small, round bulb. It goes into the same housing as the halogen headlight. The pegs to lock it in are near the base, even with each other. It says 67, sb2 on the base. I wasn't certain this was the correct bulb, so searched online. A general reference page said I need an 1157, which can't be right --- for one thing, the locking pegs are offset at different depths.
Does anyone know if a 67 is the correct bulb, or where an accurate bulb chart for the 90 Trooper is?
Old 08-11-2012 | 03:23 PM
randomorbit3's Avatar
If you are talking about the running light that is a #67 and the one mounted with the headlight is your turn signal and running light and that is a #1157. I believe you are talking about the one that is in a plastic yellow/orange housing by the edge of the fender.
Hope this helps
sammie white
09-29-2011 11:50 AM
yhata
06-05-2010 04:23 PM
collyswamper
IF Help & Suggestion Center
03-22-2008 12:27 PM
nwtraveler469
02-22-2008 09:10 AM
derek44
11-25-2006 04:38 AM
