Temp sensor(s). 02 trooper 3.5 engine
Old Nov 24, 2021 | 08:27 PM
Winterhorse's Avatar
Default Temp sensor(s). 02 trooper 3.5 engine
I get a CEL once in a while. It has turned itself off after a couple of days a couple of times.
it tests in scans as either a temp sensor or thermostat. I’m hoping it’s the sensor because the one I can see is easy to get to.
Question 1.
is there only one sensor or is there another one hidden someplace?
Question 2.
Since the car doesn’t take an unusually long time to warm up and the temp gauge reads right in the center. (Not hot) is it a pretty good bet that the trouble is the sensor and not the thermostat?
Thanks in advance.
Old Nov 25, 2021 | 03:41 PM
fourwd1's Avatar
I don't have the FSM handy right now, but IIRC there are 2 coolant temp sensors. One for the ECM and one for the dash gauge.
If the dash gauge is reading normal and the engine is not exhibiting any overheating issues, it's probably not that sensor nor the t-stat.
Old Nov 26, 2021 | 08:39 PM
That makes sense.
any Idea where the other sensor might be?
mangomonster
Feb 26, 2010 05:16 PM
dakota40
Feb 1, 2010 09:51 PM
Dixietrooper
Dec 20, 2008 11:05 PM
bigfatwookie
Oct 12, 2007 08:08 AM
wipurplechick
Nov 8, 2005 02:11 PM
