Remote Locking
Old Dec 2, 2022 | 07:09 PM
Yozza's Avatar
Unhappy Remote Locking
Hi, My son has a 95 trooper which wiil open on the fob but not lock.We have taken off the driver's side control unit from the door and spray cleaned any bits that were electrical but no joy. We have checked all fuses which are OK. Has anybody any ideas? The Trooper is quite old and well used but there must be a simple solution.
Many thanks Yozza.
Old Dec 22, 2022 | 06:37 PM
Hooligan's Avatar
You didn't mention if it was a factory installation or aftermarket. I know that most of the aftermarket units are programable to do such things as automatically lock the doors after 30 seconds among other features. If it's a factory install then it's pushing 30 years old and probably could be replaced for a much newer and more modern unit for not too much money.
Old Dec 22, 2022 | 09:56 PM
Yozza's Avatar
Hi,
It is a factory fitted system but what does the system consist of ie. what do we need to replace and where is it located on the vehicle? Many thanks Yozza
Old Dec 23, 2022 | 08:09 AM
fourwd1's Avatar
Does it work using the key?
Old Dec 23, 2022 | 09:08 AM
Yozza's Avatar
Hi, You can unlock all four doors with the key but you cannot lock the car. Each lock has to be operated separately.Cheers Yozza
Old Dec 23, 2022 | 11:13 AM
Hooligan's Avatar
The vast majority of alarm systems have the control unit installed under the dash where it is convenient to the wire harness. You can tackle it yourself but, you won't really be saving much money and, likely end up with a backache from contorting yourself trying to get under the dash. I would recommend turning this job over to a professional installer. Usually those shops specialize in window tint, stereo installations and, auto accessories. They know from experience which wires to tap into to access the door locks and the ignition system. I have a 94 Trooper and had an Eagle brand system installed for under 100 dollars but, that was here in Costa Rica. Viper is a decent brand.
Old Dec 23, 2022 | 04:31 PM
Yozza's Avatar
Many thanks for that - it is as I expected.. Yozza
malloy1
Private 'Wanted' Classifieds
Apr 19, 2018 08:48 AM
kane423
Mar 27, 2011 09:35 AM
driftwood00
Jun 8, 2010 06:25 AM
beachfairymd
Feb 15, 2010 03:36 PM
kev_mcevoy_7
Nov 27, 2008 10:22 AM
