Rear ABS Question
Old Jun 29, 2006 | 01:01 PM
davidteachey's Avatar
Good morning everyone,
I have a '96 Trooper S, and the "Rear ABS" light and the "Brake" lightare on(when starting, the light comes on for 2-3 secs, then goes out, then after about 30 secs, comes on again and stays on, along with the "brake" light"). I have disconnected, cleaned, and reconnected the connectors under the hood (under the master cylinder, and by the under-hood fuse box). The fuse is GOOD. Pulling the fuse simply results in the "Rear ABS" and "Brake" lights staying illuminated without "the 30 sec break" described above.
So, now I need to pull the rear wheels. What am I looking for? Are there obvious electrical connections? Obvious sensor adjustments? Is the ABS tone ring easily visible and checked? Any advice would be greatly appreciated! I'm trying to avoid a trip to the dealer.
I know the "normal" braking system still works as usual. But I have to get the truck's annual inspection done month-after-next, and I fear that it might fail the safety inspection if the "Rear ABS" light is illuminated, even though the normal brakes work just fine. Thanks all!
David
Old Dec 18, 2006 | 12:23 AM
DallasTrooper's Avatar
i have that same problem. i haven't had the time to examine the rear abs system....but i'm sure the sensors are just dirty
Old Apr 22, 2007 | 11:09 AM
i have the same problem with my 94 trooper. in texas, since it's not an OBD (On Board Diagnostic) inspection, it doesn't matter. i have cleaned the rear Abs sensors and done a complete brake job. the only thing i can figure out is maybe there's a glitch in the system.
yhata
Jun 5, 2010 03:23 PM
Scoutydog03
Apr 17, 2008 04:09 AM
gibsaenz
Oct 29, 2007 09:17 PM
deben2859
Aug 24, 2007 10:09 AM
pwsmith
Aug 30, 2005 09:47 AM
