Oil Leak?
Old Sep 24, 2007 | 03:23 PM
sicilian68's Avatar
Ok...I got the oil leak fixed at the oil pan taken care of. Nothing some good gasket maker couldn't cure. But I never could find a reference to an actual gasket made for the oil pan. But it turns out I had two oil leaks. After getting the oil pan taken care of and cleaned, I still had a drip coming from the transmission. Appears the accumulator piston cover is leaking some as well. Thanks to website forums, this is apparently a well known issue and I was able to quickly reference not only the issue and fix, but the part numbers for replacement parts as well. I have been told to use a half inch socket along with a pry bar to push the piston back in order to remove the snap ring. Anybody with experience know of another or better way to approach this? Once I replace the rubber accumulator cover, I'm a little weary of forcing or pushing on it in fear it might tear or puncture. Any opinions or suggestionsare appreciated. Thanks.
passport105
Jan 28, 2008 06:42 AM
sicilian68
Sep 17, 2007 08:42 AM
SteveP
Pickup
May 19, 2007 07:28 PM
MS39047
May 11, 2007 01:05 PM
Axiom35RT79
Axiom
8
Dec 5, 2006 12:10 AM
