No power to fuel pump
Old Oct 28, 2008 | 08:46 PM
Gen1troop's Avatar
Hello,
I just put a 1991 trooper back together with a fresh motor but have no power to the fuel pump. The circuit that feeds the fuel pump relay coil is dead when the ignition is on.I have12v(hot all the time) to all relays and power to all other fuses accept this circuit which includes fuses 10, 11 and 12, 12 being the fuel pump relay coil. Everything on the vehicle works outside of this circuit which, from what I can see is powered from the engine relay.I have changed out all the relays, searched the wire harness for signs of damage, unplugged the fuel pump and everything else I could think of trying but no power.Is it possible a device is blocking power to the fuel pump, ie. a roll over switch or other lock out device. Thanks for any light you can shed.
Old Feb 20, 2010 | 12:34 PM
maingauche36's Avatar
Default closure
gen1troop i have the exact same problem with my 89. Was just wondering if u had remediedthe problem,because it's making me squirrely.
Old Feb 21, 2010 | 11:00 PM
Cracker's Avatar
check your fuel pump relay, and your return relay as well
also, join up to planetisuzoo.com, and you'll get an even faster response, with pictures and everything!
tripplekill
Sep 24, 2011 02:52 AM
Thinglenn40
Apr 13, 2009 10:05 PM
Gen1troop
Oct 28, 2008 04:23 PM
compfreak530
Sep 13, 2008 05:55 PM
DubSanchez
Sep 10, 2008 07:38 PM
