needle bearing?
Old Jun 28, 2012 | 12:06 PM
rayfaith23's Avatar
Default needle bearing?
Hello,I have a 99 trooper a am having a problem with the left front wheel being well loose maybe. What it does is you can rock the tire back and forth a very little,garage will not inspect it says it needs fixed. I have checked the wheel bearing and that seems good if anything i have it too tight now so my thought is that its the needle bearing in the hub. Can you fellows comment,agree or disagree and what you think. If you think i am right would someone have a part number and where to get it? thank you,Ray
-0000-NH
Nov 11, 2009 02:14 PM
ktztrooper
Jun 10, 2009 06:40 PM
denmex
Pickup
Mar 9, 2009 12:57 PM
redsled
IF Help & Suggestion Center
Nov 4, 2008 06:10 PM
Raihnman
Aug 11, 2008 05:32 PM
