Need suspension advice
Old Oct 10, 2009 | 11:33 PM
johnnymg's Avatar
Default Need suspension advice
Greetings
I have a bone stock 02 Trooper that sways way too much from turns or even side wind. Can someone suggest a solution. Shocks/sway bar bushings would seem the way to go. Anyone have a suggestion on where to purchase 'hard' sway bar bushings/etc.
Thanks much.
Old Oct 22, 2009 | 07:41 PM
naterover's Avatar
are you sure you have a sway bar if you bought it used the previous owner might have taken it off but i guess if you asking about bushings you have taken a peek under there but i alway start with the basics its the obvious that always gets me.
Old Oct 22, 2009 | 07:54 PM
johnnymg's Avatar
Yes, this Trooper has the original sway bar. I'll have a chance to work on it this weekend: I'll verify the bar thickness (1.125" ?) and order the zerk-fitted poly bushings and the sway bar control links.
If there is anything else that is typical then please reply with suggestions. This is a very nice truck and we'll be keeping it for quite a while.
??? Locking hubs for a 'TOD' equiped Troop?
Thanks
JohnG
91trooperII
Suspension
Apr 16, 2009 11:50 AM
sa3reghatch
Pickup
5
Apr 30, 2008 08:38 PM
asbestos
Sep 25, 2007 01:21 PM
newamigo4me
Aug 24, 2007 11:18 AM
rach6178
Nov 13, 2006 03:21 PM
