low end stuttering
Old Aug 9, 2005 | 11:33 PM
supertrooper's Avatar
have a 86 trrooper with the 2.3 carb engine. i have taken all the smog control apparatus off and blocked off all the unused ports to the carb. my timing is currently at 8 degrees BTC and idles fine. however....upon easy acceleration (in any gear) or trying to cruise at a low speed (10-25 mph) the engine stutters and starts to huck-a-buck until more gas is given. am in the appropriate gear for the speeds and am planning to use it soon in the woods during hunting and dont want to esase down to my spot bucking like a bronco. any ideas on how to fix it? [img]smileys/smiley11.gif[/img]
Old Nov 21, 2005 | 01:12 AM
lowtrooper's Avatar
it could be a vacuum leak, or that the carburetor is dirty and clogged. you can also do routine tune up changes, like pcv valve replacement, air filter replacement, distributor cap, wires, and spark plugs replacement. Your problem is most probably there.
Old Mar 7, 2006 | 11:23 PM
surpera1's Avatar
a clogged catalytic converter will cause ezxcessive backpressure.this will foul injectors and plugs and give the symptoms you describe
Old Aug 31, 2006 | 12:29 AM
maverick's Avatar
on the carb thier is a cut off valve with two wires, make sure you are getting 12v to there. my 86 trooper had the same problem and that was the cause in my case. good luck
Old Dec 20, 2006 | 05:33 PM
maverick's Avatar
you could also ditch the oem carb and install a weber carb like I did !!!
best mod so far on my trooper yet!!!!
karrie01
Jan 30, 2018 02:20 PM
trooper-dave
Oct 4, 2008 11:21 PM
dan5505
Sep 10, 2007 09:54 PM
00agent
Oct 4, 2006 11:04 AM
Saty
Mar 3, 2006 03:41 PM
