ISUZU Trooper 99 DTi 3.0 engine problem
Old Sep 4, 2010 | 05:48 AM
bull5's Avatar
Default ISUZU Trooper 99 DTi 3.0 engine problem
Hi
I got a Isuzu trooper 3.0 DTI and I have this problem.
When I'm downhill or uphill, and the engine is hot, when I push the clutch the engione stops. If I leave the car in neutral, nothing happen.
If I give some gas I can push the clutch, but if I leave the car in neutral, and I push the clutch the engine stops as well!! If you have a lot of gasoline this problem happen not so often. But you you have 10-15l happn after 10min drive
I have changed the alternator and the diesel filter, and have removed all the diesel in the tank as well (I was thinking water in the tanks)
Can you help me?
Cheers
Davide
Old Sep 7, 2010 | 09:15 PM
gorilla76's Avatar
sounds like fuel pump maybe...
phantom
Jan 25, 2010 05:51 PM
Barbarojo
Jul 9, 2009 07:34 PM
Dixietrooper
Dec 20, 2008 11:05 PM
emailaak
IF Help & Suggestion Center
Dec 15, 2008 09:53 PM
91isuzupup
May 24, 2006 05:39 AM
