How to install 1995 Trooper driver’s side axle snap ring
Old Apr 6, 2021 | 04:17 PM
Antifa's Avatar
Default How to install 1995 Trooper driver’s side axle snap ring
How to install 1995 Isuzu Trooper drivers side axle snap ring
Old Apr 12, 2021 | 08:52 AM
Hooligan's Avatar
You know, you could add a few more words and let us know what it is you're having problems with. Do you have snap ring pliers?
Old Aug 21, 2022 | 11:12 AM
sdowney717's Avatar
I think they mean the outer thin snap ring, it can be a tight fit. You have to pull or push the axle shaft all the way into the bearing hub, and make sure nothing is in the way of doing that. I have with the outer bolt cover off, used big pliers and pulled the axle hard into the hub. May also lightly pry where the groove is to pull it tight to the cover to fit the snap ring onto the end of the axle.
Old Aug 22, 2022 | 07:52 AM
fourwd1's Avatar
Since this thread is over 1 yr old, I'm guessing the OP has figured it out by now
IrishRifles
Sep 7, 2013 10:46 AM
johnny5ive
Jul 6, 2012 10:18 AM
lazy733
Apr 5, 2012 05:01 PM
dangingrey
Private 'Wanted' Classifieds
Oct 9, 2007 12:37 PM
first trooper
Feb 9, 2007 03:42 AM
