GROANING 2002 trooper
Old Oct 29, 2009 | 08:45 AM
trooperdrury's Avatar
Default GROANING 2002 trooper
Hey all, I have a 2002 trooper with 109,000 miles on it, We've owned it since it had 19,000 miles on it. Replaced the transmission at 98,000 miles, and it has had this INTERMITANT groan between 35mph and 45mph, and really is prominent when the temperature is cold out. I have talked with a mechanic and one said the rearend needs to be replaced. I asked him if changing the gear oil would eliminate the noise, and he said no... they have never looked inside the case. I talked with another mechanic and he said to change the fluid and run a high end synthetic in it. the rear end fluid has never been changed as long as ive owned it, and the noise does come from the rear end....
Anyone had a similar issue with this? any suggestions? Thanks
Old Oct 30, 2009 | 07:56 PM
wheily's Avatar
id do the fluids espacially if it hasint been done are you sure ther is fluid in it?
mandkpritch
Mar 8, 2008 10:39 PM
g2turbo
Nov 11, 2007 10:10 PM
TINAis
Sep 13, 2007 04:53 PM
g2turbo
Sep 13, 2007 01:14 AM
firsttroop
Aug 23, 2007 06:33 PM
