spark plug platinum or not
Old Nov 2, 2009 | 11:38 AM
security11122's Avatar
Default spark plug platinum or not
I want to replace my spark plugs. Do i really need double platinum plugs or not. I have a 98' 3.2 v6 205hp engine. They don't need to be change but i want to change them.
Old Nov 2, 2009 | 04:56 PM
wheily's Avatar
they do last a little longer but i dont buy them unless im getting a good deal. but its ur choice
Old Nov 3, 2009 | 03:37 PM
Well i will go with the platinum and not the double platinum. At $2.40 a plug that isn't bad for 6 cylinders
Old Nov 3, 2009 | 07:31 PM
MEphenSean's Avatar
How is "double platinum" better than platinum? Sounds like marketing BS, though I am no expert. And if you don't think you need them, I wouldn't bother changing them. If your plugs are okay, you don't have much to gain by swapping in new ones. If your gaps are right and the electrodes are not worn or corroded and covered in carbon, whatever you have should be fine. Platinum doesn't necessarily produce a better spark, in my understanding. It is used because it doesn't wear as quickly as copper. I'd say keep your plugs (if they're good) and suggest your significant other super size it when you take him/her out with the money you save! (No, not suggesting that McDonalds is fine dining to you, just acknowledging that plugs don't cost that much.)
Just my $.02
Sean
Waylander
Apr 9, 2020 02:39 AM
security11122
Nov 2, 2009 11:33 AM
Kinnie
Jun 30, 2007 10:02 PM
Sparkplugs.com
Dec 1, 2006 03:39 PM
joewildlife12
Dec 6, 2005 07:55 PM
