dose anybody know anything
Old Jan 28, 2007 | 08:09 PM
bobbyl1989's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
dose anybody know anything on this fourm?
Old Jan 29, 2007 | 09:51 PM
ISUZUGURU's Avatar
Super Moderator
bold question for a newbie
Old Jan 29, 2007 | 11:55 PM
bobbyl1989's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
well if asked abunch of questions and no onehas answered any of them haha
Old Feb 3, 2007 | 11:43 PM
ISUZUGURU's Avatar
Super Moderator
dont get discouraged so quickly,there are alot of info in this forum.an alot of knowledgeable people here also.sometimes the reponses are slow.i dont believe i saw your questions.sometimes you have to post them more than once
Old Feb 5, 2007 | 12:38 PM
bobbyl1989's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
ok the questions i was wondering about was a rocker is hanging up on my 94 trooper ls and i also if they make altezza tail light for it?
Old Feb 5, 2007 | 10:01 PM
MASTERTECH's Avatar
Is your trooper a dohc or a sohc, if it is a dohc it may not be the rocker it may be the chain tensioner in the front of the cylinder head each head has a chain running the cams, Is it making a tapping noise? If it is on a sohc the rocker arms and shafts are worn, you can try, 3 things change the oil and on one oil change use 0w-30 mobile one sync, or try 5w-40 rotella diesel oil, or the expensive way replace the rocker arms and shafts
Old Feb 7, 2007 | 10:34 PM
bobbyl1989's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
its a dohc
Old Feb 7, 2007 | 10:41 PM
  #8
MASTERTECH's Avatar
sound like a timing chain tensioner problem
Old Feb 15, 2007 | 08:53 PM
  #9
atfdmike's Avatar
How did you diagnose a "rocker hanging up", did you pull the cover, check compression or what? Is it just one rocker, or are you just assuming, and based on what? Are you sure that is case, as several rockers are affected by cam timing chain problems, usually not just one......or am I wrong?
Old Feb 16, 2007 | 09:12 PM
  #10
MASTERTECH's Avatar
usually there are several rockers that are noisy, with the amount of work you would have to do its better to change them all, then try to piece it together and have to go back later
tamaforlife
Jun 3, 2012 01:21 PM
asghilo
Feb 13, 2009 07:57 AM
NvMySi
Oct 26, 2007 06:18 AM
natedog2088
Nov 30, 2006 02:49 AM
