< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> dose anybody know anything on this fourm? |
bold question for a newbie
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> well if asked abunch of questions and no onehas answered any of them haha |
dont get discouraged so quickly,there are alot of info in this forum.an alot of knowledgeable people here also.sometimes the reponses are slow.i dont believe i saw your questions.sometimes you have to post them more than once
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> ok the questions i was wondering about was a rocker is hanging up on my 94 trooper ls and i also if they make altezza tail light for it? |
Is your trooper a dohc or a sohc, if it is a dohc it may not be the rocker it may be the chain tensioner in the front of the cylinder head each head has a chain running the cams, Is it making a tapping noise? If it is on a sohc the rocker arms and shafts are worn, you can try, 3 things change the oil and on one oil change use 0w-30 mobile one sync, or try 5w-40 rotella diesel oil, or the expensive way replace the rocker arms and shafts
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> its a dohc |
sound like a timing chain tensioner problem
How did you diagnose a "rocker hanging up", did you pull the cover, check compression or what? Is it just one rocker, or are you just assuming, and based on what? Are you sure that is case, as several rockers are affected by cam timing chain problems, usually not just one......or am I wrong?
usually there are several rockers that are noisy, with the amount of work you would have to do its better to change them all, then try to piece it together and have to go back later
