Audio-Subs.
hey bro i can help with that i got mine ran along the dorr jams just under the carpet but make sure you run the rca wires along the opisite side from the power wire my ground is conected to my rear seat bracket in the floor
yeah i ran mine thru the big gromit where the mane engine harness comes in the fire wall just cut a small hole alittle smaller than the wire you r using then push the wire thru it will be tight but that make make sure it will still be sealed up airtite
