95 trooper bogs out on acceleration
Old Apr 28, 2019 | 10:42 AM
roger s's Avatar
Default 95 trooper bogs out on acceleration
i have a 95 3.2 sohc trooper ls. engine idles fine but when accelerating it bogs down. its showing obd code 42. ive checked crank and cam timing, replaced vacum lines, manifold gasket, cleaned fuel injectors, flushed gas tank, replaced ignition control module, fuel filter, spark plugs and crank sensor, also check catalytic converter still has same issue. i would be very grateful for any help i can get. thank u
Old Apr 14, 2023 | 01:15 AM
sethr1996's Avatar
Did you ever get anywhere with these issues? My 95 is doing the same thing and I'm at my wits end. Wanting to fix this pile of crap up but I can't get over the issue. When I unplug the O2 sensor it runs really rich and mpg goes to 6 but it will at least run good
Old Jul 24, 2024 | 07:20 PM
Jimmysrigg's Avatar
Did you check and clean throttle body ,what was dicription of code .
brianvn99
Aug 22, 2021 01:41 PM
MrMopar
Mar 10, 2018 02:08 PM
Cody Atkinson
Oct 23, 2017 10:53 AM
91trooper4x4
Jul 30, 2011 07:09 PM
flamefighter2
Jan 30, 2010 04:01 PM
