90/no clutch pressure..
Old 05-19-2010 | 04:29 PM
thepooper's Avatar
Default 90/no clutch pressure..
I'v got a 90 trooper that has no clutch pressure.. I replaced the slave cyl once, and it was working. few days later, no pressure. bought another and put it in, nothing. I'm going to relpace the Master cyl next.
I'm trying to figure out what this manifold thing is.. "From the Master cyl there is a line that runs into this box thing that has the bleeder screw on it. from that a line runs to the slave cyl."
Does anyone know the name of that "box". -all ideas will be looked into
Old 05-20-2010 | 08:28 PM
ramzoom's Avatar
In order to reduce the clutch squeaking noise, damper cylinder is used in clutch hydraulic line between master cylinder and slave cylinder.
The damper cylinder has a 4 screw/bolt cover..
This is how to disassemble:
1. remove cover and gasket
2. Damper rubber
3. Piston assy.
4. spring
5. Cylinder body
Check damper rubber and piston cup for cracks, deformation or damage. replace the damper cylinder assy if nec.
That is straight from the Isuzu workshop manual.
They use the word "Damper cylinder".
Hope this helps.
Old 05-21-2010 | 02:26 PM
thepooper's Avatar
Thanks, I misplaced my FSM. I'm going to check right now
BonesMachine
08-22-2011 11:48 AM
trooper-dave
10-05-2008 12:21 AM
bmck
IF Help & Suggestion Center
11-19-2006 04:03 PM
im5811mp
03-06-2006 04:10 PM
dwoody1
06-07-2005 08:02 PM
