Help with an Issue...
Old Jan 9, 2012 | 06:58 PM
nguyennp's Avatar
Default Help with an Issue...
Check engine light came on on my '04 Rodeo. AutoZone diagnostic says there could be something wrong with the MAP sensor but, as far as I can tell, the '04 Rodeo does not have a MAP sensor. Correct me if I am wrong.
Could it be a blown intake manifold gasket causing the error? If so, how could I tell for sure? Any insight would be much appreciated.
Thanks in advance.
Old Jan 17, 2012 | 02:29 PM
panther.stealth's Avatar
if there is a blown intake manifold gasket, your mileage and performance would be noticeably worse. and most likely your coolant would look like chocolate milk/shake and likely have a boil over. (this would be due to oil coming through the gasket into your coolant chambers etc.
paulauryn
Feb 8, 2012 07:31 PM
Uticon
Mar 26, 2011 07:38 PM
isuzukids
Apr 8, 2010 01:53 PM
89troop1
Mar 27, 2009 01:05 AM
trooper90
Dec 1, 2006 04:49 PM
