87 Trooper Fuel pump Replacement
Old May 10, 2021 | 06:38 AM
Gman's Avatar
Default 87 Trooper Fuel pump Replacement
1987 Trooper 2.3L
Replacing fuel pump but wanted to know if i go electric pump , how should the fuel line be routed . Which lines need to be blocked off .
The problem I am having is : went to replace oe mechanical pump and mounting spacer cracked and I can not find a replacement spacer .
jda1981
Feb 4, 2020 09:18 AM
tuttle
Jul 22, 2018 01:54 PM
LtJay4
May 29, 2010 03:33 PM
antdhernandez
May 10, 2010 08:29 PM
teribul
May 8, 2008 04:18 AM
