86 Trooper C223T OIL LEAK
Old Mar 12, 2007 | 02:50 PM
MS39047's Avatar
Hello
I have taken my 86 Trooper II out of mothballs after two years and she fired up like she did in 86[img]smileys/smiley4.gif[/img] However there is an oil leak when the engine is running. A steady drip, drip, drip from the passenger side of engine belowand near the area directly beneath and to the back of the oil filter area. Before I start to dismantle everything in that area to trace - is there a known failure prone to this area so that I can zero in quickly? Any thought or ideas are welcome!
Old Mar 13, 2007 | 02:24 PM
atfdmike's Avatar
Hi, found only one bulletin regarding Isuzu rear engine oil seal, so your leak may not be related.There is a UV dye you can add to engine oil and they using black light trace oil leaks to source. AS an alternative, and I don't recommend them personally, there are additives that swell gaskets and seals that might rejuvenate your engines vitals. Good luck
BULLETIN NUMBER
SB92-01-002
ISSUE DATE
March 26, 1992
GROUP
ENGINE
REAR OIL SEAL LEAKAGE
AFFECTED VEHICLES
All Isuzu models.
SERVICE INFORMATION
Diagnosing engine oil leakage requires careful detection of the exact source of the leak. A "Crankshaft Seal Leak Diagnosis and Installation Procedure" job aid, provided by Federal-Mogul. It describes procedures for diagnosing engine oil leaks and replacing the rear crankshaft oil seal. To ensure proper diagnosis, these procedures should be followed to determine crankshaft seal effectiveness.Edited by: atfdmike
Old May 11, 2007 | 01:05 PM
MS39047's Avatar
Following up late but with a conclusion. There is a small steel line (like injector line) that was leaking on the back rear of oil filter mounting plate. Real PIA to get off - The line was rubbing against a mounting bolt for filter housing to engine.
....and now you know the rest of the story.
Mosesmosley
Aug 10, 2011 09:40 AM
mgriff
Jul 8, 2009 06:52 PM
sicilian68
Sep 17, 2007 08:42 AM
SteveP
Pickup
May 19, 2007 07:28 PM
Axiom35RT79
Axiom
8
Dec 5, 2006 12:10 AM
