2001 Trooper Auto Tranny Help !!!
Old Jul 30, 2011 | 04:58 PM
Oregon_Trooper's Avatar
Default 2001 Trooper Auto Tranny Help !!!
Hi
I have a 2001 trooper Auto , i had a shop rebuild the tranny because it wasnt shifting on its own , and i got it back but its still not shifting one its own , any one know what it is or might know whats wrong with it
Old Jul 30, 2011 | 07:13 PM
Lunchbox21984's Avatar
like how is it shifting on its own. its a Automatic transmission, its suppose to shift on its own, its controlled by the computer. if you don't want it to shift on its own and by you shifting it, then you need to pull the auto out and put in a standard trans.
Need to explain a bit more about your issue to get a better answer. is it shifting at weird RPM's or is it dropping out of gear at the wrong time. Worst case you might have to get the Transmission Computer Reprogrammed. If you have Oversize tires on it, it will throw your whole shifting pattern off as well as make the trooper ride different.
Old Jul 31, 2011 | 09:04 AM
No its a Auto , but its Not shifting on its own ...
I have to do the auto Manually Start in 1st then shift it by have , and im not post to do that , ITS a AUTO
tikker
Mar 28, 2010 06:25 PM
Windy
Mar 3, 2010 11:36 AM
mark
Jan 31, 2008 09:03 PM
beerbrewer
Aug 13, 2007 03:42 PM
jleland
Feb 3, 2007 11:52 PM
