1991 Trooper (2.8L V6, Manual) Suddenly Stuck in 2nd Gear and Won’t Come Out
Old Sep 22, 2024 | 11:23 PM
91troop5speed's Avatar
Default 1991 Trooper (2.8L V6, Manual) Suddenly Stuck in 2nd Gear and Won’t Come Out
1991 5-Speed Stuck in 2nd Gear
I picked up my 91 Trooper 2.8 V6 from a location 1 hour away, then drove it home the hour back to my house (only thing it needed was coolant).
no issues, but shifting seemed “delayed” if that makes sense? Would release clutch and then about a fulls second later it would drop into gear.
I get home, hang out letting it sit and then go to the store down the street.
I proceed to get to a light intersection and I try throwing it in second and releasing the clutch and it gets stuck between what I believe is second and 4th?
It’s jammed in there and had to tow strap it down the street home with another truck.
Any suggestions?
Also, is my gear selector bottom bushing broken? (in photo circled in red) Can’t find the original and how it is suppose to look online anywhere.
TLDR; 91 Trooper 5 Speed 2.8. V6 gear selector lever STUCK between two gears. Clutch pedal disengages and reengages clutch because gears grind when I let down clutch pedal.
Old Sep 22, 2024 | 11:27 PM
For some reason my device won’t upload but it’s a 1/4 inch thick white donut shape right now.
jaypizzthebizz
Feb 22, 2016 05:09 PM
trainman123
Mar 2, 2014 04:00 PM
TinPecker
Dec 29, 2012 03:51 PM
MGud
Nov 20, 2012 01:31 PM
bigRedTrooper
Jan 5, 2007 02:24 PM
