1988 trooper issues
Old Aug 18, 2007 | 03:39 PM
brody11's Avatar
I have an 88 trooper 4 cyl.
Driving home the other day and my A/C stopped or at least the blower? Most of my idiot lights came on including battery,O2,oil,gas.
I made it home and turned the ignition off. I turned it back on and the warning lights are all still on and the car runs for awhile than stops. Almost like its not getting gas. I changed out the fuel filter,O2 sensor,distributor(crank sensor). I had one trouble code on the computer, 4 flashes, pause, 1 flash. My manual indicated that code was for a crank sensor, or the wiring. I put a new distributor in. Still the same problem. I'm begining to think that code was from the past owner, and just never erased it. I unhooked the gas line from the tank to the filter (where the fuel pump is), plenty of gas coming out of it when I start it? It almost seems like a sensor or electrical problem.
Running out of guesses!!!! Any Ideas?
Thanks.
Old Aug 18, 2007 | 09:50 PM
frank's Avatar
Thanks.
reset the ECU (computer) and see what happens.
Old Aug 19, 2007 | 09:23 AM
brody11's Avatar
Is there another way to reset it other than just unplugging the plugs from the computer? That's what I did a couple of days ago.
It removed the code but I still have the warning lights and the car trouble.
Old Aug 20, 2007 | 06:02 AM
frank's Avatar
pull the ECU fuse and let it sit for a little while. Generally I also pull the negative on the battery as well.
Old Aug 21, 2007 | 11:19 AM
NCISUZUTECH's Avatar
Check your alternator. If it is not charging correctly the lights will not go out, and will affect fuel pump operation. also check your grounds. I have seen alot with the ground on the back of the head and the valve cover missing.
Goodluck
Old Aug 29, 2007 | 09:13 AM
brody11's Avatar
After finally giving in and taking my isuzu to the shop, turns out all it was was a bad alternator. Not enough juice to run the A/C, and also why I had all the dash lights. I just don't understand why the car didnt give me a trouble code for the alternator? Good call NCISUZUTECH. I should have just purchased a new alternator. I just didn't want to keep buying parts, not knowing for sure.Edited by: brody11
Jim Pifer
Jul 29, 2007 12:33 PM
amcmb1968
Jun 24, 2007 08:01 PM
houptee
Jan 3, 2007 10:09 AM
graysilm
Nov 28, 2006 02:57 PM
Jim Bob
Jan 24, 2006 10:16 AM
