1986 Trooper turbo diesel RPM issue
Old Sep 27, 2020 | 03:08 PM
Hutch23's Avatar
Default 1986 Trooper turbo diesel RPM issue
Hi, I’m a new member and just bought this. I’m going thru it and getting it in good shape but I’m having a strange issue where it won’t go past 2300-2400 RPM’s. I did oil change, belts, air filter. 111k miles and engine sounds really good but just can’t get it to get past that 2300 to 2400 RPM’s. Any advice on where to start looking? It is the turbo Diesel engine. Thanks, Cy
Old Oct 3, 2020 | 06:08 PM
geusterman's Avatar
Hi Cy. I have that Trooper and all rebuilt. Fuel would be first...getting enough. So make sure filters are clean. There is a filter under the intake line going into the pump. A little screen. Last place to look. Make sure fuel flowing at pump and each injector. Might be an injector not popping. Another idea is idle stop at the pump...make sure throttle has full range of motion. All I can think of at the moment. George
Old Oct 3, 2020 | 07:39 PM
Hutch23's Avatar
Thank you George! I will go thru those steps tomorrow
Old Oct 10, 2020 | 10:36 AM
Hooligan's Avatar
Is the car smoking at all when accelerating?
Old Oct 10, 2020 | 11:00 AM
Hutch23's Avatar
No smoke
Old Nov 15, 2020 | 07:23 PM
geusterman's Avatar
Also Hutch, there is a little screen under the intake side of the pressure pump and (for whatever reason!) on the exit side. Might be gummed or something. Be careful on banjo bolts...be nice.
TruckaDucka
Nov 20, 2012 01:40 PM
1990Trooper
Feb 21, 2012 02:24 AM
jkhadley289
Jul 27, 2011 09:35 PM
i44i
Mar 28, 2009 11:50 PM
skidmarc
Apr 12, 2007 06:57 PM
