01 Trooper Tranny issues
Old May 29, 2017 | 08:32 PM
timsand68@gmail.com's Avatar
Default 01 Trooper Tranny issues
I recently purchased a 2001 Trooper limited with 117,000 miles. Looks and runs perfect. I bought it because the previous owner spent $2400 for new rebuilt transmission. It worked for a month and now ONLY reverse works. The previous owner was refunded her money since the mechanic couldn't figure it out. ? I looked through the glove box and found a receipt​ for a rebuilt transmission dated in 2013. So what could be the Problem with this transmission?? It's 99.9% new! HELP ME!!
Old May 30, 2017 | 06:39 PM
fourwd1's Avatar
This is a bit of a long shot, but maybe the transmission range/mode switch.
It's mounted in the side of the trans where the shift lever mounts.
It tells the trans ECM what gear the trans is in (or should be in).
They go bad and send false info to the ECM.
Otherwise it could be a big trans problem.
Old May 30, 2017 | 06:53 PM
Thank you so much for your opinion as I need as many as I can Get.
pancholin
Sep 13, 2014 11:52 AM
amc5
Oct 11, 2008 11:28 AM
beerbrewer
Aug 13, 2007 03:42 PM
cootershooter
Apr 24, 2007 10:51 PM
jleland
Feb 3, 2007 11:52 PM
