Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it...
Squeeking from rear when going over bumps
Old Jul 18, 2011 | 02:42 AM
Gdafpaaa's Avatar
Default Squeeking from rear when going over bumps
Has developed an annoying squeek from drivers rear
Cannot get it by bouncing up and down on stationary vehicle but driving over bumps sounds like I have been infested by Philips mice!
Any ideas?
Old Jul 20, 2011 | 05:47 PM
StanZ's Avatar
I had a similar problem after the dealer did the frame repair recall on my ' 99 Rodeo. Turned out to be a rusted out rear bumper bracket that had broken during the repair and was rubbing metal-on-metal when I hit a bump. Once I found it I just had to bend the pieces away from each other.
Mine was in the left rear corner but there is so much rust that it could be anywhere.
Hope you find it!
Old Sep 23, 2011 | 11:46 PM
Taylorcarter's Avatar
I'm also looking for some advices about this case
Old Sep 26, 2011 | 02:53 PM
StanZ's Avatar
Other than checking every bracket joint in the rear, no. Also check the screws that hold the fuel filler neck and and the shock mounts.
Has it been in for the rear frame recall? If something there is severely rusted you may have metal-on-metal contact and squeaking before it finally lets go.
Good luck,
Stan
ISUZUGURU
4
Dec 3, 2007 06:05 PM
mntrooperdiesel
Aug 13, 2007 02:50 AM
cowboys78
Jun 12, 2007 12:10 PM
gruntsky
Pickup
Dec 27, 2006 03:04 PM
