warning light problem
Check the wiring on the frame by the right rear wheel leaf spring hanger going to the top of the rear axle. It''s for the rear ABS speed sensor. If there is a problem with the wiring or the sensor it will make the rear ABS & BRAKE warning lights stay on.
See my post in the new member area under sorta new here. I posted it by mistake when I first joined the forum.
Hope my experiences are helpful.
Best regards, Lefty249 Guy
Does the brake light get brighter when you pull the e-brake? Usually when they both come on the brake light is kind of dim but gets brighter when you pull the e-brake. This means either bad sensor or the wires are bad as lefty mentioned.
Dude. I have the same problem! the Rear Anti-lock and theEbrake light. sometimes the check engine comes on and off while I''''m driving tooit''''s so weird. Thanks for the answers guys that''''s been bugging me forever. I''''ve replaced the senors [in the front]numerous times trying to fix it! Edited by: brynnespot
